Message |
So what is your opinion on the rack and pinion or replacing of the power steering pump? Thanks for the info about the bulbs. Is there a way to check wether it is a bad solder joint?I had read that the valve cover gasket was simply unbolt some stuff, align it, and bolt it back down. Is that not the case? Why expensive? Thank you again for all the info
